10" wheel on Foxbody
7.2K views 21 replies 14 participants last post by  AllStockRacer
#1 ·
Anybody running a 10" rim on a Foxbody Stang?
#17 ·
15x10 with 6.5" BS is the common size. If the car is mini-tubbed with a stock width rear you can go 15x10 with 7.5" BS and have the tire tuck inside the fender lip perfectly. Could possibly fit a 15x12 with 7.5 or 8.5" BS also with mini-tub and stock width. Then again when its mini-tubbed, you should have the rear end narrowed before buying wheels so you can go deep dish with like 4.5" BS. They look better.
#20 ·
Im running Azev Type C's -17X10's with 315/35/17 M/T drag radials in the rear and 17x8.5 with 245/40/17's on the front. Both my 89 Coupe and 91 GT have the same wheels and setup.... You will need to either flip the quad shock around or remove it and roll the fender lip in. Oh both cars are lowered with Eibach Springs..
#22 ·
Im ordering some 15x10 Convo Pros tonight or tomorrow and my backspace is wrong on the two that I have. Im going to run a 275/50/15 which is a 26.x/10.83/15 if I order them with a 6.5 backspace am I going to be ok... This car has stock style wolfe fully adjustable. no quads on drag springs with a bag. car launches hard just dont want to destroy tires coming down on them or what ever. The ones I have are 15x10 with a 3.5 or 4 in backspace
