1 - 20 of 24 Posts
Hi everyone. New to the mustang seen and have a few questions. I just inherited a 92 coupe that i am doing a 4cyl conversion on and want to put a 331 under the hood. It is originally a 5speed car, my question is how much Horsepower would i be looking at coming from a 331 and also would a t-5 transmission be able to handle the power? Or would i need to go with tremec, c-4 or built AOD or something? Im kinda on a budget also so im looking for the most cost effective way to get it on the road as fast as i can. Thanks guys
you cant see me
if you want cheap , keep the car as light as possible, race on slicks not drag radials, and use a cobra t5, just dont miss a gear.
Discussion Starter · #4 ·
We'll i dont men like cheap cheap like i would have to drive with caution lol i just mean like which would be cheaper to keep it manual or go automatic with the power of a 331?
Rambling Man
I've seen stock t-5's live thru hell with a good driver. I've also seen modified t-5's crater with a completely stock 5.0.
AOD's have to be built by a reputable transmission guy.
C4's will work out for a little while with a shift kit and an extra band.
Taking away the weight of the car will be some of the best insurance to saving your drivetrain.
Cool man thanks for the reply, I think im gonna go with a c-4 from phoenix transmissions over in weatherford i have a friend who got a trans from them, resonably priced, looked great, and he beats the hell out of it haha
I seen a TKO and a Tremec for sale over on www.westsidemustangs.com, might be something to check into.
Only downfall to a C4 is the loss of overdrive. My first C4 from Performance Automatic lasted over 3 years on the footbrake running low 12s eventually down to mid 11s before rebuilding.
No, no, no, NO!:banghead:
If you are going the automatic route...Mike's Trick Shift all the way 817-657-1419
How do you put an extra band in a C-4 really I would love to know:confused2:
Wow, drunk post for the loss. I meant extra clutch.
I can by that. You need to do a little more to a c-4. Prob. be more cost effective to just put a TH-350 in it.
Rambling Man
I've often wondered what the cost would be to do that. It would be incredibly difficult for me to convince myself to put a chevy transmission behind a Ford motor, but we'll see.
To have a c4 built to hold the power doesn't seem too far off from a built TH-350, moneywise, then you've got to get an adapter.
The parts for a TH-350 are much stronger in stock form. And there many more aftermarket option for the TH-350 then the C-4. The only advantage the C-4 has is it fits the ford all ready and its lighter which is also its draw back i.e. small weaker components. The bell is around $300.00 I can build a fairly stout TH-350 for $600.00. It will last longer than a $600.00 C-4. IMPO
T5-T56-Tremec specialist
If its a pure drag car , go to Ebay and look up ******* Performance . Grab one of their C4 with converter packages and call it a day . I have one behind my 408W and its holding up great .
<----------- coming from a guy who builds T5's every day .
WRECKIN' BALL BITCHES!
especially when i see guys putting aods behind chevys!
HA. dont do it...unless you want mike to have to fix it. ive seen them build a lightning trans 3 times in a row, only for mike to have to fix it..
817-657-1419 mcgee is the man
Rambling Man
Right!! So many people think the AOD is shit. In stock form, sure, it won't last long.
Now, I've been comparing power levels and prices between Th-350 and C4. It seems the average prices are still cheaper to get a c4 that'll hold 700hp versus a th-350 that will do the same and I would still have to get an adapter.
I'll be sticking with my Ford stuff, and it will be coming from Mike's trick shift.
23
oh hell here we go!!!!!!
i guess all my C-4s that i had built where just flat out piles of shit.
i had one from Huges and and when it took a crap i did alot of research and i called Mighty Might and they sold me on a $300 drum that was brass filled to strengthen the drum. dont know why they sold me on the brass filled drum,but i trusted the "Pros".
the c-4 took a crap once again,then i went with a PG,it went faster with the PG.
then everyone said go C4 it will go faster.
well with my experience i will never use a C4,not even as a boat anchor.
a built T350 is by far a tougher trans than a built C4 "PERIOD".
as far as a AOD behind a chevy i would say the aod is very similar to a T400.
but i can promise you there is not a ton of aods in a all out strip car.
yes there is some out there i am aware.
1 - 20 of 24 Posts
