What style of rotors do you like best?
  • Crossed - Drilled
    Votes: 1 10.0%
  • Slotted
    Votes: 2 20.0%
  • Crossed Drilled and Slotted
    Votes: 4 40.0%
  • Dimpled
    Votes: 0 0.0%
  • Dimpled and Slotted
    Votes: 1 10.0%
  • Stock Replacement
    Votes: 2 20.0%
Dirty Mexican
Crossed - Drilled
Slotted
Dimpled
Dimpled and Slotted
Stock Replacement
IA2
The $17 autozone ones.
From what I understand all of the slots and holes were necessary in the old days because the pads would give off "gas" when braking and the holes & slots gave the gas somewhere to go, improving pad/rotor contact. Supposedly the holes aren't necessary now and simply lead to early cracking of the rotor.
The Janitor
crossdrilled to me is worthless. All it is doing is putting stress fractures into the rotor. Slotted is better, but by no means perfect. The pads still give off gasses, and also heat that comes with the friction of braking.
I'm callin you out!
I like the ones that come on dirt bikes. I guess they are cross drilled??? Not sure. But if they put those on those things then they have to be the best.
