ok.. i got on my car today for the first time (since getting the motor in and running good).. and i guess the clutch was not fully seated... I power shifted into second.. powershifted into third... and it would then not pull out third...
my qustion is.. i lost almost half my clutch pedal.. I curious if I can get this back somehow or do i need get a new clutch?? i have the stock clutch cable not adjustable.
If i need to get a new clutch.. What is a good (preferably cheap) performance clutch??
· Scared s**tless
i doubt you can get the pedal back, unless you just stretched the cable.
it sounds more like the pressure plate is going out. i would say, just replace the disc and plate in one go. there is no sense in installing a new pressure plate to have it kill a worn out disc.
i am using a Star Spec stage 4.
