1 - 20 of 23 Posts
FTH!
What's the best exhaust/turbine housing to use for the TD-04 compressor in single app. Finished my install, drove the car and no boost until 5000 rpm. Its running a HUGE housing so I guess I need to come down in size. Any help is great....
World Record Holder!
What size motor?
What mods?
And where do you want to boost the come in at?
I've got a single PT51 (comparable to your turbo) system on my car (302 with good heads and intake). I've got a .69 exhaust housing and I've got 4psi by 1700-1800 and full boost by 2500-2600. The down side is that it's done by 5400 or so. A .81 housing will get you full boost by 3200 or so. I wouldn't go any bigger than that on a ligthly modded 302.
If you aren't getting boost until 5000, you probably have a 1.13 or so.
Scared s**tless
if you have a powerstroke turbo, they aren't the best for quick spooling. VERY large exhaust sides...
what are you running don?
Merry HoHo
DonSVO said:
whats that rats nest doing under your hood? oh, my bad thats your wiring:D
i wonder two of those things would do for a twin set up on a V8. i know bryan is spinning the hell out of his two little turbos, but how much more would a T3/T4 flow? and add ball bearings to that. can you say booooooooooooooooooooooosted baby.
Scared s**tless
as long as i can supply the airflow *headwork, exhaust* mine will efficiently produce 425 wheel horsepower.
Scared s**tless
they run out of power range a tad early, due to the stage III/.50 trim compressor. but i made up for that by getting a custom camshaft ground and retarding it 4*.
FTH!
Discussion Starter · #11 ·
Thanx for the input guys, sorry I did not explain what was on the car in full. The housing that is on there now is a tang/divided cast, I think from a powerstoke or cummings. So an .81 should do it on a non-internaly modded 302? I want to achieve peak boost at around 3500 or so with little mods to the down pipe. I'm new at the turbo thing so I'm going to keep buggin' ya'll:D
FTH!
Discussion Starter · #13 ·
Well, Victor wants to change the housing on the setup due to serious lag, dont get me wrong, if fly's above 5000 but shit you hardly notice it cause it's gone as soon as it gets there. Plus it only get mabey 3psi before you have to shift:confused: A couple of days and I'll give you a ride in it:D
Scared s**tless
barely boosting at WOT??? 4 PSI???
i wonder if the wastegate and/or actuator isnt open, and therefore bypassing the turbine...
I've also been wondering how well a pair of those hybrids would work on a 302. When I plotted the operating line on the compressor map, it looked like it would be very close to the surge line at the lower revs (3000 rpm) at 15 psi (2:1 pressure ratio). But, that was based on calculated mass flow, not actual measurements. If Don can make one work on the 2.3, there shouldn't be any surge problems with 2 of them on a 302. Don, how much boost are you running, and at what rpm do you have full boost?
1 - 20 of 23 Posts
