my car was the pig and now I'm open for converting yours. 02' dual piston calipers. stopping is a good thing.
how does it look you likey?
You can't, if you're attaching images.William Wallace said:how do you put more than one pic in a reply?![]()
Actually, installing SN95 brakes on a Fox is pretty straightforward. The spindles bolt right up, and you can use the Fox balljoint, provided you use some spacers between the spindle and the castle nut (SN95 balljoints are about 3/16" shorter.)Mustang Heaven's Shibby said:How much of a pain in the ass was that? Or did the spindles bolt right on with some brake line trick-work?
SWEETCLEDUS said:SWEET!!! I love the stance.![]()
