DFW 'Stang Forums banner
what all is needed when you converting from speed density to mass air? How much can i expect to spend converting it?
You will need a computer 89-93, mas air meter and the harness from ProM.
I would recommend using the A9l computer, the harness from ProM is 54.95
and they don’t list it on the web site, just call and they know what you need.
Good luck
so that is it? that is the only two things i need to convert from speed density to mass air? then why dose summit want nearly 600 bucks for a conversion kit ?
How you doin'
you need a computer and either a harness from a mass air car, or you can get the mass air upgrade kit from pro-m...then you just have to run a couple of wires and add a couple of pins in the eec harness connector...i have an A9M computer, if you need one.
brad
