LUCIFER
I've got the Powerslot Slotted Rotors, do these have to be installed any certain direction?
Does the slot have to be going a certain way? Their directions said it would function fine either way, but I'm curious if anyone else had any info on this?
My concern is my rear brakes/rotors are already starting to turn my rotor color quick! The fronts look fine but the rear are starting to fade a bit...is this normal?
Doesn't make any difference. The slots aren't cut on an angle so even if you turn them around they would still be in the same position.
It really shouldn't matter, but I was always told to have the slot "bite into the pad"
