1 - 20 of 20 Posts
Does any body know what this block is? Is the block any better than the stock?
orld class no.
world class yes. It is an aftermarket block it depends on the line but they are better than a stock block.
If you found one at a reall good price, you should pick it up.
How do you know what block it is, is there a link to check the numbers? Also the on I have now has an uneven bore in two of the cylinders its .40 over and I am wanting to do a stoker 331 would it hurt me to bore it over .60?
Discussion Starter · #7 ·
sorry type-o world class
Discussion Starter · #10 ·
So if I sleeve it will that hold up to a 331 fine? with trick flow heads, stage 2 trick flow cam?
Also can I go with a bigger cam?
Discussion Starter · #11 ·
also with 1.7 rockers?
WRECKIN' BALL BITCHES!
.40 over is well into the water jackets...:yikes: .040 would be ok
Discussion Starter · #19 ·
Wcp block
I personally wouldnt worry on that block...if its what you say it is. have it sonic tested to be safe
Where would you take the block to be sonic tested?:trink26:
1 - 20 of 20 Posts
