11-05-09
Ok, Before I left to San Antonio last week, I made sure everything worked on my GT, and it checked out ok. Earlier today, when I went to start it, it hesitated, and I had to fight with it for a few minutes before it started. I flick the lights on, the Instrument cluster doe NOT light up, but the exterior lights do. The fuse is not burned. What gives?
the resistor that dims the panel lights! Mine does the same thing, but i havedt bothered geting a new one yet. Sometimes when i get in the car it's on and sometimes off. Simply move the dimmer back and forth and see if the panel lights come on. Good luck.
chris
i would say that the resistor in the switch has gone out. if you can get a test light and see if you are getting power to the switch. if you are see if you are getting power to the other side of the switch.
