1 - 13 of 13 Posts
if you're reading this you've probably read my other post.. i need to get the car home, it's at a friend's house.
gonna replace the eec relay tomorrow.. if that doesn't work is it possible to just bypass all the fuel pump relay shit... just cut and splice into the fuel pump wiring and make my own switch?
could i wire it straight into my acc on the fuse box?
if i run a switch then i need it to be fuse protected.. what size fuse? 15, 25, 30?
thanks, brien
Discussion Starter #2
update:
- new ignition switch
- all fusable links are working properly
- new fuel pump relay
- eec relay is clicking, so i'm guessing it's working
the fuel pump relay has power coming in at the red/orange wire.. but the pink wires have no power
any advice?
Brien, ive got a "new" relay from a parts place, and it kicked my ass for 2 days till i put a known working one in. Ended up being bad/wrong relay even tho it fit and was new.
600 plus a few
the new relay he put in was tested in my car and it worked. its perfectly fine
Rookie
skidmark said:
update:
any advice?
That is exactly what happened to me.
You have a bad ground wire somewhere. Did you find the black wire with the green stripe on it?
Discussion Starter #11
no i did not, but every ground in the engine bay looks to be correctly grounded.
i bypassed the tan/lt green wire on the fuel pump relay which is a ground from the computer and made my own ground.
the fuel pump turns on when it's suppose to, but the car will still not start.
Rookie
Well, it only makes sence that the other wire needs to be grounded still...
Discussion Starter #13
that is true, but now when i bypass the ground, the pump turns on and whines..
but no fuel is coming out. i disconnected the fuel line from the fuel filter and nothing is coming out at all
1 - 13 of 13 Posts
