Form Lighting is excited to introduce our Sequential LED Tail Lights for the 2015-2022 Ford Mustang!
If you are looking to update the rear end of your Mustang, swapping the tail lights is one of the easiest things you can do to make a big impact.
Stand out from the crowd. The S550 is known for its signature triple sequential turn signal. These lamps not only retain that functionality, but make your Mustang stand out with modern 2018+ styling, and three different lens colors available: smoked, clear, or OEM red.
Red. This is a great option for 2015-2017 Mustangs looking to update their tail lights to the more aggressive styling of the 2018+, while keeping the OEM red appearance.
Smoked. A dark appearance, great on black and grey vehicles. Using grey-tinted optics, these smoked lights have a clean OEM-style appearance, rather than a painted-on look you get with tint films.
Clear. Perfect for white and silver vehicles, the clear lens option is a brighter look, while still providing distinct “Euro” styling.
OEM-Grade Construction. Form Lighting tail lights are built with quality in mind and constructed using OEM-grade materials, including a UV-coated polycarbonate lens, automotive-grade LEDs and optics, and direct-fit connectors. While they may not be the cheapest option on the market, the fit and finish of our lamps is superior to other aftermarket units.
Road Legal. All three lens color options illuminate with red LEDs for running lights, turn signal, and brake. They are SAE and DOT-compliant for on-road use.
Plug-and-Play. Our tail lights for the Mustang are completely plug-and play and will fit perfectly, without any body gaps. Installation is a breeze and can be done in minutes. They were designed to plug into your factory tail light connector, with no additional wiring needed. There are no errors, flickering, or hyperflashing.
Click the video below to see HOW to install our 2015-2022 Ford Mustang Sequential LED Tail Lights!
Two-Year Warranty. All Form Lighting products are rigorously tested for reliability, and backed by a two-year warranty. The warranty is supported directly by Form Lighting, and any replacement parts, if needed, are shipped quickly from Form Lighting’s US warehouse. In the rare occasion that you may need to utilize your warranty, we try to keep the process as simple as possible - for example, no return is normally necessary.
Do you have additional questions? We’ll be happy to help!
• Reply to this thread
• Send us a direct message
• Email: [email protected]
Are you a US forum member? DM us for a FREE shipping code!
Jordan M.
Form Lighting
