FREE advertising FTL!
The 360 is an "FE" engine and the Boss 429 was based on a 385 series block. Can't make a Boss 429 from a 360 mill. Find an early 460 block and start there.As my username implies I had a 2000 SS Camaro convertible. Buddy (on these forum) has a '95 GT with a 351W.
After watching/helping with his build I'm turning to the dark side - going Ford for my next build. Chevy aftermarket SUCKS!!!
I'm looking at doing a '96 mustang. I have access to a Ford 360 block and was wanting to stroke it to a 429 to do a BOSS 429 themed car. Later on I plan to install a ProCharger, and will repaint the car (probably have it partially wrapped).
I've seen 430 stroker kits, but was wondering if anyone had a build up on a 360/390 already?
Any tricks to shoe horning a 360/390 block into a '96?
Should I just can the 360 stroker idea and just look for a 429?
Thanks for the help!
Keep it between the ditches!!!
i knew it sounded odd, but ive never done any of those series...good info,DavidThe 360 is an "FE" engine and the Boss 429 was based on a 385 series block. Can't make a Boss 429 from a 360 mill. Find an early 460 block and start there.
Also, building a faux Boss 429 will eat your lunch ($$$). Be prepared. The 390 was basically a truck motor and not a good RPM mill either. Nice torque but a 385 series would be much better.
David
351W isn't big enoughfair enough...if you think chevy aftermarket sucks, drop the 360 idea...base it on a windsor. you can get 430+" out of a windsor and tons more cylinder heads/intakes avail, and the cost will be better. AND youll have more room
roflmao, not only no, but hell no.Put an LS1 in it. :sombrero:
I can find a 360 to 430 stroker kit. That's pretty close (if I went that route I'd still put the BOSS 429 branding on it).The 360 is an "FE" engine and the Boss 429 was based on a 385 series block. Can't make a Boss 429 from a 360 mill. Find an early 460 block and start there.
David
so 434 inches isnt big enough? yes, a windsor is considerably more compact imo351W isn't big enough. 460 will have to be the power plant.
Is the 360 that much physically bigger than a 351W?
No need in "branding" it as a BOSS 429. The heads are semi-hemispherical combustion and look similar to a Hemi head. You can't put Boss 429 heads on an FE series (360/390) block. I would also guess that components for that 360 based mill would be expensive. Personally, I would take greenbullits suggestion and stroke a Windsor block to 42++ inches and get the cubes you want. The aftermarket is much better for that block, which is a 90° block as opposed to the FE series which is wider and takes up more room.351W isn't big enough. 460 will have to be the power plant.
I'd just build another camaro if I was going to do that.
Think I'll keep an eye out for 460s or 385 series.
I'm planning to go all out. I'll basically only have the vin # as the only original part after I'm done. At least that's the plan.
That's why I started the thread. I wasn't familiar with the Ford stuff so wasn't sure which way I should go.The "Chevy aftermarket SUCKS" but somehow I've missed the big wide world of stroker FE and Boss 429 speed parts.Hmm.
These things all have about the same approximate cost:
Rebuilt FE Ford
Stroker kit (crank, rods, pistons, bearings, rings) for FE Ford
Stroker kit for 429/460 Ford
One bare cylinder head casting for Boss 429
Complete 600hp small block Chevrolet
You can buy a complete 600hp sbc for $800? Fuck, hook me up.The "Chevy aftermarket SUCKS" but somehow I've missed the big wide world of stroker FE and Boss 429 speed parts.Hmm.
Rebuilt FE Ford
Thats funnier than chevy aftermarket sucks"Chevy aftermarket SUCKS"
Should be rephrased: "Late model Camaro aftermarket SUCKS"
This is going to be a screaming street/drag car. Just a toy.If it were me who was "going all out", I would get an aftermarket block based on a 351w, stroke it to 393w, add a set of trick flow heads, hang a couple hair dryers off to the sides, and have a custom cam done to tie it all together.
That's not a complete 460 for $800, it's only the stroker kit.You can buy a complete 600hp sbc for $800? Fuck, hook me up.
http://cgi.ebay.com/ebaymotors/BUDG...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Stevo
I'll go with an aftermarket front suspension (mustang II or something similar). Get the right springs and it should handle the extra weight well enough for what I want to do with the car.Also remember that the 385 series engines weigh a ton. With that much front weight bias, the car will handle like shit. If it's going to be a drag car, not so much of a concern, but if there are corners in your future, go with the 351.
LS aftermarket is great?Thats funnier than chevy aftermarket sucks
LS aftermarket is great! Hell you can make nutty power using stock parts!
That's pretty cheap. Not sure I would trust it, since it's about half of what quality parts go for. I was thinking a number around $2k for all the things I listed.You can buy a complete 600hp sbc for $800? Fuck, hook me up.
Stevo
