1 - 15 of 15 Posts
· Vendor
2015+ Mustang
Our Sequential LED Headlights are the perfect way to upgrade your 2018+ S550 Mustang. With these premium OE-grade replacements, you’ll add sequential turn signals, a startup sequence, bright DRL, and a more aggressive, modern appearance.
Startup Sequence. These headlights are packed with the latest and most modern lighting functions, including a startup or “welcome” sequence. Anytime the running lights turn on, they will illuminate in a two-stage chasing sequence that is sure to turn heads, with an ultra-premium look.
Sequential Turn Signal. The startup sequence isn’t the only thing that stands out. These headlights also feature an integrated sequential LED turn signal. Every time the turn signal is activated, amber LEDs activate across the bottom of the lamp in a smooth, chasing sequence. When you’re finished making your turn, they automatically “switch back” to the bright white DRL.
Increased Light Output. These headlights feature a bi-LED main projector, which provides increased output for both low beam and high beam. The beam pattern has a sharp cutoff, with excellent center intensity and strong width to illuminate the road ahead. For high beams, there are also two extra LED reflectors, providing a triple high beam output. These reflectors throw additional light far down the road for excellent high beam performance.
OEM-Grade Construction. Form Lighting headlights are built with quality in mind, using OE-grade materials and design techniques. This includes durable UV-coated polycarbonate lenses, automotive-grade LED emitters, breather vents, and OEM plug-and-play connectors. You can rest assured that these lights will provide durable and superior performance for your S550.
Road Legal. Form Lighting headlights meet all SAE, DOT, FMVSS, and CMVSS standards and regulations for legal on-road use in the United States and Canada, when installed and aimed properly - which is easy to do with the integrated screw-type adjusters.
Plug-and-Play. Our headlights for the Mustang are plug-and-play for the main functions, along with a single wire tap if you’d like to enable the sequential turn signal feature. They were designed to plug into your factory headlight connector, and they fit perfectly without any gaps. No errors, flickering, or hyperflashing!
Click the video below to see HOW to install our 2018-2023 Ford Mustang Sequential LED Headlights!
Two-Year Warranty. All Form Lighting products are rigorously tested for reliability, and backed by a two-year warranty. The warranty is supported directly by Form Lighting, and any replacement parts, if needed, are shipped quickly from Form Lighting’s US warehouse. In the rare occasion that you may need to utilize your warranty, we try to keep the process as simple as possible - for example, no return is normally necessary.
Do you have additional questions? We’ll be happy to help!
• Reply to this thread
• Send us a direct message
• Email: [email protected]
Are you a US forum member? DM us for a FREE shipping code!
Jordan M.
Form Lighting
· Vendor
2015+ Mustang
Discussion Starter · #2 ·
Click the video below to see HOW to install our 2018-2022 Ford Mustang Sequential LED Headlights!
Jordan M.
Form Lighting
NOW through 7/8, all FORM Lighting products are 10% off!
No coupon required.
This discount will be automatically applied at checkout.
Click HERE to visit the FORM website!
· Vendor
2015+ Mustang
Discussion Starter · #7 ·
Jordan M.
Form Lighting
Prime Day savings are here! Ends midnight CST, 10/12/22.
NOW through 10/12, you can get 10% off at our Amazon store for Prime Day!
No coupon required.
This discount will be automatically applied.
Click HERE to visit the FORM Amazon store!
· Vendor
2015+ Mustang
Discussion Starter · #9 ·
Jordan M.
Form Lighting
LAST CHANCE for 15% off LED headlights for your 18+ Mustang! Form Lighting's Black Friday Sale ends TONIGHT!
No coupon required.
This discount is automatically applied.
CLICK HERE TO SAVE AT THE FORM STORE!
· Vendor
2015+ Mustang
Discussion Starter · #10 ·
ONE. MORE. SALE. 🏷
Now through 1/5, you can get 15% OFF all FORM Lighting products exclusively through Amazon and our authorized dealers.
This is your last chance this year to save on our LED headlights for your 18+ Mustang!
Shop our Amazon store ➡ Form Lighting
· Vendor
2015+ Mustang
Discussion Starter · #11 ·
There’s only a few days left to save!
Through midnight 1/5, you can get 15% OFF all FORM Lighting products exclusively through Amazon and our authorized dealers.
Start your new year off right with some fresh headlights!
1 - 15 of 15 Posts
