need Patio Ideas
3649 Views 36 Replies 8 Participants Last post by  henrycolter2
We are building a home and adding a patio... we are/were looking at stained and stamped concrete, but it's running about $14 a sq/ft for the size we're looking for i.e. 100sq/ft.
Any suggestions for anything else? I looked at flagstone stuff, but they seem to say if you want to put a table on it, go ahead and do it "wet", so the price is basically the same because you pour a concrete base and lay the stones in it.
Wondering if anyone has any great ideas? I'm not a landscaper by any means, but I want something that is durable, looks good, and will be able to handle a patio table and chairs without leaning or "teetering" all the time.
If you have an idea, please post up a picture, or post a picture of your patio. I asked my wife if she would mind a concrete patio, and then acid staining it after, but she wasn't really feeling that.
Thanks!
1 - 20 of 37 Posts
lots of lookers...
Landscape guy quoted me at 12sq/ft for some stone layout... not even flagstone. He said something about putting an elastic like finish between the stones so that weeds/grass couldn't grow through the cracks. he also Tried to tell me how concrete would crack and look bad.
lots of lookers...
If you insist on concrete, how about an exposed aggregate? When the pour it, they use a little different mix, then brush off the top layer of cement. Looks great, it's cheap, and really durable. If you want, you can even spray on a clear sealer to darken it and protect it.
I would go with stamped concrete. There are lots of designs and colors to choose (or mix) from, and once its in you can keep it up yourself w/ an annual powerwash and reseal.
The landscape guy didn't lie to you - concrete will almost 100% guaranteed crack - but if it is saw cut, chances are it will crack inside of the cuts and shouldnt be visible. Most stamped patios are at least 6 iches (i'm not 100% on the requirements here) where you're average driveway is only 4. Since its thicker, and you won't be driving 4,000 pound vehicles on your patio, it shouldn't crack in the middle of sections like some driveways do.
For $14 a ft. they can kiss my ass...
I'm still a little torn on the subject
What about when they pour my driveway, I have them pour the patio and stamp it w/ my stamp I want. I then go back and acid stain it or something of that sort on my own? Does anyone think that would be a good idea at all, or just a wast of time? This would make the concrete pretty cheap in itself.
I'm really not sure what an aggregate is... I guess I'll have to look this up!
If you can pour your patio at the same time as your driveway, you should get a better rate. A ten by ten pad is a half day job and not a whole lot of concrete, so adding it on when they do the driveway would be preferable for most crews. 10x10 at 6 inches is 2 yards of concrete - most companies (at least in CLE) have a 4 yard minimum load charge. If you do decide just to pour a patio, you may get a better price per sqft by going a little larger.
If you pour it with your driveway, they may be able to fit enough for the patio on the same truck - otherwise they will need a small balance load. If there is enough left over from the balance of driveway truck(s), they could add color to the mix at the end of the load.
IMO staining is only for borders and accent designs - I don't believe that non-colored concrete w/ a stain would look as good as colored concrete. Your primary color should be mixed directly in the concrete w/ accent release color(s) dusted on top while stamping.
For example, the light brown in this picture would be the result of the mix in the truck and the colored release powder(s), and the dark brown would be because of the same mix, release, and adding a stain.
Thanks for the info. I think 3 yards is the smallest you can get here, I know I was looking at right around 2 yards. They keep trying to have me make it bigger, but I just don't have enough yard. I like my grass too much.
I've seen stains that look very close to the same as colored concrete, but it is different. I just don't know how acid stained concrete would hold up.
Here's a couple examples of what I was talking about, I would chose a similar color but would be on a slate stamp:
If you want to keep the patio small, I would recommend doing it with your driveway, or trying to find a place for another 2 yards - do you have a front or side service walk on your house? We did several jobs that did these two areas at the same time as a patio and they kept a normal uncolored driveway. Whatever you decide, I definitely think decorative concrete is way better than real stone or any other patio options...
No sidewalk on my side of the street.
I'm going to see if he'll pour it when he pours our neighbors driveway, taht way they don't fuck it up when they are grading the yard for our sod.
When you say decorative concrete, do you mean w/ the color integrated w/ the concrete? I'm a little confused w/ that. Before you were telling me you didn't think the acid stain would look very good, but I though acid stained concrete is decorative concrete... as you can see I'm trying to learn, but I appreciate your answers! I think the guy who is doing our driveway just really doesn't want to do it... so that's why he says $14/ft
My builder seems to think that finished concrete just won't look good... I don't know why. He keeps insisting it will crack and look bad. I don't agree w/ him, maybe he's just trying to have his landscape guy make some extra dough.
Stained and stamped concrete are good for patios. They are strong, durable, look good, and will be able to handle a patio table and chairs effortlessly. They also wont cost much.
What a nice information post thanks for making this valuable content post it is very interesting content provide I like it
Steve Trevor Wonder Woman Jacket
This place is proof of the beauty of Australia. Australia is the most beneficial country for visiting with family on vacations Write For Us
Calgary Commercial Construction is a wholesaler manufacturer specializing in refrigeration, air conditioning and commercial kitchen ventilation products. Our extensive product line ranges from the most basic of ductwork to more advanced systems which include integrated dampers, fans, filters and controls.
Online Vape Store provides a curated line of premium e - cigarettes and accessories, available at an affordable price.
We are a group of event professionals working to provide you with high quality Event spaces Ontario.
With close attention to detail and innovation, Mens Barber Shophas helped establish Aurora as a premier destination for men' s grooming. Guests can enjoy an experience that is as enjoyable as it is pampering through exorbitant lounges, beautiful furniture options and flooring, sparkling glass mirrors and professional service from a team of experts devoted exclusively to male clients and guests will want to return again and again.
Land financing Toronto is a type of financing that is used to purchase raw land for development or investment purposes. This financing can be provided by banks, credit unions, private lenders, or government programs, and can be structured in a variety of ways to meet the needs of individual borrowers.
A certified coach with Neurodiversity Coach, Coach Jessica Michaels uses her life experiences as a catalyst for sharing what it means to live with neurodiversity in the mainstream. She believes that everyone has a right to their own personal expression and empowers clients to pursue whatever goals make them happy. Whether it be pursuing passions or creating a family, those are goals worth celebrating, no matter how they were defined before.
1 - 20 of 37 Posts
