DFW 'Stang Forums banner
Ok, I may be getting a car with trickflow twisted wedge heads. right now it has an E cam with 1.7 rr's and pro-products intake 75 mm t/b and 24 pound injectors with a 76 mm c and l all on a 310 bottom end. I have a set of AFR 185's that need to be fixed should I fix them and use them or the TW's? now here is the big question I need help on FAST, I have a trickflow stage 2 cam should I use it or a XE266HR? thanks.
Should I run the tfs stage 2 cam or xe266hr? Right now the car has a e cam with 1.7's and doesnt run as good as it did with a B cam and 1.7's so I know IT CAN run better with a different cam.
