FIRE!
Anyone install a water temp guage on a mod motor??? Where did you put the temp sensor at???
FIRE!
Discussion Starter #2
ttt
I put my sensor in the u shaped coolant rail on my car. your 2 valve doesnt have that but you may be able to use one of the spots where your stock temp gauge sending unit is. there are 2 sensors on the front of the motor one dr side one pass side (cant remember which is which) one is the sending unit for the ecu the other sends a signal to your stock temp gauge. if you used a T you could use both your stock gauge and your aftermarket one.
FIRE!
Discussion Starter #4
Thanks, for the info.
anyone whos done this on 2v feel free to throw in your 2cents
FIRE!
ttt
FIRE!
Discussion Starter #6
Come on surely someone's done this on a 2v!
FIRE!
Discussion Starter #7
ttt
FIRE!
Discussion Starter #8
ttt
