1 - 7 of 7 Posts
How would I know if my mass air is going bad..Sometimes it sounds like it is having trouble taking in air and makes a weird sound. Would this cause an idling problem.
Bad mass air meters can cause hoaky idle conditions, but not always. Your best bet is to swap with a known good MAF sensor and try again.
Rolling with the homies
Have you tried cleaning out the hot wire in the MAF? I assume you've cleaned the filter to right? Is it a stock MAF? Maybe someone might have one you can swap in.
1 - 7 of 7 Posts
