1 - 10 of 10 Posts
What intake would do the best on my car with stock heads and cam. It's is a 94.
stock.......not, i am going to go with the systemax.
¯\(º_o)/¯
I'd say a GT40 intake.
Out
Hogan sheet metal;)
Really, the GT-40 would be good so you won't lose your low-end torque. I would only use it on a mild set up.
With a set of good aftermarket heads and a stout cam, I'd go to the Trick Flow intake.
I got a cobra intake and that netted me 245 to the wheels. Not bad for just a bolt on car with stock heads and cam. That would be the budget way, I like the holley, or the trick flow intakes.
If you look around you can find a good deal, I picked up my cobra for a little over $200, you could do the same.
1 - 10 of 10 Posts
