1 - 19 of 19 Posts
I'm in the process of installing the terminal block, etc, to hide all the wiring in the walls. My question is this. I bought 16 gauge 4 conductor wire (HiFi Works) from Fry's. So it's 4 coated 16 gauge wires, in a plastic sleeve (red, white, black, green). Seems to me that 16 gauge wire really wouldn't be thick enough, but I don't know shit about this. Should I double up on the wiring, and run say two to each positive terminal, and two to each negative terminal? Or should I run all four to each positive, then another four to each negative? If I were to do it 4 to each, it may pose a problem as all wire ends will be banana clips, and getting all four wires to fit in one banana clip may be a big task.
I know with car audio the thicker the gauge the better, wouldn't it be the same with home audio?
My current setup is an Onkyo 606, Polk RT10s, CS3, PSW505. I haven't bought the rear speakers yet. Keep in mind, I will be going bigger soon. I've been nothing but frustrated with my Onkyo receiver, and will likely be going pre/pro in the near future. I don't want to restrict this in any way, or have to redo anything once the sheetrock is back up. TIA for suggestions.
is chilaxing
I'm no pro or anything, but I would just do 2 to each side. When I ran my surround, I ran roughly 25-30ft of 14awg. Not sure how big you want to go later and the distance.
Im with you on thinking bigger is better. I'm sure 16 gauge may be ok for low amperage setups but I would double it up. I ran 10 gauge on mine. It was a pita though but I went behind the baseboards so that's why. Better safe than sorry but I'm not a serious audiophile.
Discussion Starter · #8 ·
16ga is fine. 14ga would be better, but 16ga is gonna work just fine. No need to double it up.
Interesting. 16 gauge was the largest they had at Fry's, and after looking online 16 gauge seemed to be the standard.
It wouldn't hurt anything to double up, would it? I've got more than enough wire, and will have plenty left over, even if I were to double up.
Hedge your bets and triple up!!!
lol, this place sucks now
Wouldn't hurt anything, but I don't think the benefits are worth the extra (although minimal) effort. I'm sure a true audiophile would tell you that the twists per inch would cause acoustical phasing issues from doubling up, but I'm not sure I'd worry too much about it.
All that being said, I would just run the 16ga, wire up the black and red wires, and call it done.
Discussion Starter · #14 ·
You're not pushing that much power through the rear channels. 16 ga. will be fine.
Its not just the rears that I am wiring up. I'm wiring the whole thing. Towers, center, sub, cat5, coax, etc. I'm going to see what a 100' spool of 14 gauge would cost me. I'll either scrap or try to sell what's left of the 16 ga.
I pre-wired my room with 12 guage. I DO think wire makes the difference, especially when pushing it a good distance. I used 150' of it in my 16x15 media room. By the time you go up a 10' wall and across the ceiling a couple of times, it makes sense. Once that wire is there, it's there forever, so I probably spent a little more than necessary.
I've had great luck with 16 gauge Monster XP speaker wire. Even on long throws.
Discussion Starter · #18 ·
http://www.monoprice.com/products/p...=10239&cs_id=1023901&p_id=3844&seq=1&format=2
I ran this for my home theater and it is great quality, inwall rated and perfect for longer runs. Probably overkill, but cheap insurance.
Thanks Mark, that's a steal at that price. I think I paid $129 for my 100 feet of 4 conductor 16 gauge. It's really all Frye's had. They did have shorter rolls, but all were 4 conductor and all were 16 gauge.
I'm about to place an order for the 12 gau. Before I do, I have another question. I ordered all the banana clips from monoprice a while back, but they didn't come with the plastic compression rings. I've looked all over the site, and can't find any. For instance, the GE brand that Home Depot sells have plastic compression rings that help hold the wire in tight. Problem with this, is they are $6 for a package of two. I don't want to spend $100 or more on just the banana clips. Will I be fine without the compression ring? Should I solder? The ones I bought say no solder required. Here is the link to the ones I bought.
http://www.monoprice.com/products/p...=10401&cs_id=1040115&p_id=2801&seq=1&format=2
Just install without the rings - the Monoprice bananna plugs do not offer any strain relief, but the price is right. - I also had a couple that were loose.
1 - 19 of 19 Posts
