1 - 2 of 2 Posts
check to make sure the pcv valve isnt clogged, or the metal screen under it. on other thing, check the voltage at idle on your tps. you can also check it with key on engine off. you want to get it just under one volt, like .97,.98,.99. you get the idea. if its higher than that, it will idle badly. let us know.
stroker95
1 - 2 of 2 Posts
