Man Just go with a carburetor conversion and be done with it
Both of those cars were originally speed density cars.
When you had whoever pull the running gear out of the 87, they should have pulled the wiring harness/ecm/mass-air meter and installed it in the 88 that way you keep your mass-air setup. If you don't have the 87 anymore, you can buy a mass-air conversion for the 88. That will help with the running problems.
I've got a brand new conversion harness(from LMRS) and a used A9L that I will not be using since I went with an aftermarket EFI control system.
+1 on the injectors being too big.
Late model resto's harness is from Pro-M racing, it can be seen here:Sent you a PM, How much for the harness? Is it hard to install it? I have my old A9L that is programed for the 30lb injectors so I would be using that. Can you send me a picture of the harness at this email?
[email protected]
