1 - 14 of 14 Posts
Discussion Starter · #5 ·
hmm, I changed the filter and when I pulled the old one off fuel just sprayed all over the damn place. Gas flowed throught the filter fine. Somewhere after the filter is the problem. The Fuel pressure guage reads like 5psi. It will start for min but stumble and die.
good to hear you found the problem.
it's probably the pump, but you do realize that when you hit the key, the pump only turns on for a second, right? it has to take input from the TFI for it to run constantly... IE, if the engine dies, the fuel pump stops pumping.
Forrest
1 - 14 of 14 Posts
