I've been through a few converters. Stock with the AOD, then when I built a motor for it, went with a Precision Industries (
www.converter.com) Stallion 2800 rpm converter. It hit right close to 3000 rpm behind a 347 with heads/cam/intake, etc... and cut 1.61-1.63 sixty foots n/a on average. I then switched to a C4 transmission by Performance Automatic and a PA 3000-4000 rpm 10" converter. That converter hit about the same as the PI converter 3000 or so and the car sixty foot 1.60, but picked up some ET due to the lighter weight transmission and less rotational mass.
Recently with my current 347, I switched to an 8" Trans King converter. When I first got it I was told it hit at 5000 behind a 600+ horsepwer mod motor car on nitrous and that it should be something around 4200 behind my motor. Not the case, on the dyno I stabbed it to the tune of 5200 rpms before settling down and pulling to the 6250 rpm rev limiter. That converter was awesome for 60 ft, but it slipped a lot on the big end of the track getting me a 1.54 sixty foot and
[email protected] I pulled it and had it tightened up and now I think its hitting around 3500 or so (will found out on the dyno tonight). The car has run 1.59 sixty foot and
[email protected] mph with the re-stalled 8". Tonight I'm going to get a chip to bypass the factory rev limiter and then do some more track tuning to see what I can get out of it. If I can't get it down to 11.1x range then this converter may come out in favor of having my old 10" PA converter re-stalled and put back in. The 10" converter is way more efficient on the top end. With this 8" converter, on the nitrous I hit the rev limiter at the 1000 ft mark and only trapped 121mph off the gas, with the old one the car trapped 126mph under the factory rev limiter.
So that said, a 10" 3000 stall would actually be totally streetable. With the 10" in the AOD, it really felt like a stock converter when daily driving, but would annhilate the tires at WOT. With the 8" converter I have now, it feels pretty loose and revs on up over 2000-2200 or so to really get moving easy from a light.
