I thought I did!
I deleted.. c:winnt\system32\config and that directory is now empty. Is this the right file to delete?
If not what is the command I need, to finish this job?
AbecX has the SAM file and said he was trying to crack it last week but I havent heard back from him.
redGT said:
I thought I did!
it shouldn't be empty, all you had to do was delete the SAM file, and reboot...if there is no SAM file there, then there should be no local Admin pass..
¯\(º_o)/¯
I have to run a bute force hack on it, it'll take forever.
98 SVT Cobra
Try this, obtain a copy of l0phtcrack. L0phtcrack specializes in
breaking SAM files and includes a lot of advanced features. Now,
unlike .pwl file cracking that takes at most 1 hour, SAM file
cracking COULD take up to 24 hours on a Pentium 2 400 Mhz
system running l0phtcrack non-stop. You can get a copy of l0phtcrack
by clickinghttp://www.atstake.com/research/lc/download.html .(please
note that it is a demo version that is still fully functional)It comes
with some basic help and instructions. First off, take the SAM file
and copy it to your desktop. Once you have it there, go run
l0phtcrack and then select "File" then "Import SAM" and then go
select the SAM file from your desktop and begin having it cracked
my friend. Now it is just a matter of leaving your computer alone.
(tip: Set it all up before you go to bed that way when you wake
up, it will have already hopefully cracked it for you. That way
there is no loss of productivity in using your computer.)
I think we need a forum just for computer related questions,
there seem to be alot of them.
¯\(º_o)/¯
MoonDog said:
(please note that it is a demo version that is still fully functional)
The demo doesnt let you run the brute force method.
98 SVT Cobra
If you need it that bad, I will meet you at my office in Carrollton at 190 and 35 and have it fixed for you in 10 minutes. PM if you are interested. I'm going there this afternoon.
-Chris
