I bought their Comp fuel system tank to rails and there is no F**king way the rails are going to fit....I knew there were issues with clearance problems on the d/s front rail/ distrib. but I assumed since both Aeromotive and Dallas Mustang parts said that it fit no problem, that issue has been worked out.
How have your guys been doing this?? I am not about to wack out part of the rail and weld it up as the front injector is at the end of the rail and lopping off the top edge seems like a bad idea.....but I have seen a lot of guys running aftermarket rails with the 94-95 body style with the stock type distributor. Mind you this is with the port plug at the end and exiting the middle of the rail......somebody who has done this give me some useful advise!!!!!!! thanks.
