Fel-Pro 1152 Graphite
what do yall recommend to use with gt40 heads and the car will be on the spray. it will be a 125-150 dry shot.
9333pt1what do yall recommend to use with gt40 heads and the car will be on the spray. it will be a 125-150 dry shot.
Ditto.9333pt1
yup worked great for my 95gt, my store even had them in stockDitto.
And you can order them at your local parts store and have them the same day too.
doh!hope i made the right decision , i got the Fel-Pro 1152, and they are already sealed down. will try to put the motor back in on monday.
no they are arp. well if i blow it I plan on just sticking this car to the side and getting on the race car.ohhh..
They are just replacement stockers. If you re-used the stock bolts, you are doomed. 100% garunteed.
Whoops!hope i made the right decision , i got the Fel-Pro 1152, and they are already sealed down. will try to put the motor back in on monday.
Why ask for info. you dork. Might as well have gotten the 8448 at Vatozone if you weren't gonna listen.hope i made the right decision , i got the Fel-Pro 1152, and they are already sealed down. will try to put the motor back in on monday.
yall didn't respond till like 2 or 3 days after I posted it. And I bought it them before seeing the post.Why ask for info. you dork. Might as well have gotten the 8448 at Vatozone if you weren't gonna listen.They have the 9333 as well. I think I can get those for about 22 a pair
You will be fine. I used to spray (150 shot) my old iron headed motor with the 1152's all the time and never had a problem.
