bump anybody?
No, I do not. I've never had a car do this before. I can drive and hold my foot steady on the throttle and then it will act like a couple of spark plug wires just got pulled off of it. Then it goes back to normal. Then a mile or two later, same issue. Does not matter what speed, gear or RPM range I am in.Mine was doing near the same thing (89 Lx 5.0) and after changing numerous parts to chase it down, I swapped the ECM out and that fixed it. Do you have another one to swap out and check it?
No check engine light. Grounds are all good and I replaced the TFI a few hours ago thinking that was the issue. I started thinking more and more that it is the fuel pump or fuel pressure regulator.any CEL's??
I tend to believe fuel pump, or regulator. Although, I'd get the TFI tested and check your grounds.
That is exactly what mine was doing... run rough for a few seconds and then clear up, then start again. If I clutched and reved it a couple times, it would clear up for a bit, then start over.No, I do not. I've never had a car do this before. I can drive and hold my foot steady on the throttle and then it will act like a couple of spark plug wires just got pulled off of it. Then it goes back to normal. Then a mile or two later, same issue. Does not matter what speed, gear or RPM range I am in.
Yup. That is what it is doing.That is exactly what mine was doing... run rough for a few seconds and then clear up, then start again. If I clutched and reved it a couple times, it would clear up for a bit, then start over.
Hmmmm.Prior to the computer swap I changed the plugs, wires, cap, rotor, maf, tps, cleaned the IAC, fuel filter, and air filter.
The fuel pump will typically make more or less noise on priming. If the regulator is bad, the fuel pressure goes way up and it will typically run like shit and smell REALLY rich.What are the signs of a bad fuel pump?
What are the signs of a bad fuel pressure regulator?
maybe if you all could help define those issues I might be able to narrow it down
Sounds interesting as well. Based upon what you are saying, I do not think the fuel pressure regulator or fuel pump or bad.The fuel pump will typically make more or less noise on priming. If the regulator is bad, the fuel pressure goes way up and it will typically run like shit and smell REALLY rich.
There's a possibility that you have a bad injector or two. I'd start the car and spit or spray water on the header tubes one at a time while the car is full running temp. If the water bounces off, move to the next cylinder.. until you find one that the water is sticking to the header. It's the cheapest, tried and true problem solver.
