If it get louder is it going bad. i can hear my wine over my exst.
Z Z4 Mustang · Registered Joined Apr 4, 2002 · 466 Posts Discussion Starter • #1 • May 10, 2002 If it get louder is it going bad. i can hear my wine over my exst.
V Vertnut · Premium Member Joined Nov 15, 2001 · 18,368 Posts #2 • May 10, 2002 Fuel pumps- get louder with age. Not necessarily going bad, but put a new fuel filter in. Fuel pump replacement really isn't bad.
Z Z4 Mustang · Registered Joined Apr 4, 2002 · 466 Posts Discussion Starter • #3 • May 10, 2002 where is the fuel filter located on a 92 lx 5.0?
M MrStang · Registered Joined Dec 15, 2000 · 365 Posts #4 • May 10, 2002 It's located in front of the gas tank, right in the middle. You can't miss it, it has 2 gas lines that plug into it.
Z Z4 Mustang · Registered Joined Apr 4, 2002 · 466 Posts Discussion Starter • #5 • May 10, 2002 Thanks
R Ross Manning · Registered Joined 8 mo ago · 3 Posts #6 • 8 mo ago Yes, replace fuel filter. It will reduce the noise a bit. Fuel pumping replacement isn't that costly as well.
L londders · Registered Joined 7 mo ago · 1 Posts #7 • 6 mo ago My fuel pump became louder before it died.
esther1524 · Registered Joined 2 mo ago · 4 Posts #8 • 1 mo ago Thank you for sharing this post. It helps me a lot. 770haulers.com/
superpro · Premium Member Joined Mar 31, 2000 · 1,465 Posts #9 • 13 d ago The pump does get louder with age but still functions without with its rated flow/pressures.
