Ok over thanksgiving i am changing the Rear main seal. and i was thinking that i might need to get my flywheel resurfaced while i was at it. I am NOT puting a new clutch in unless i find that i need one. the clutch that is in it is a king cobra with about 5,000 miles on it. Does the king cobra clutch use the same through-out bearing? Thanks. chris
heavy weight
ditto don't sufface it if your not going to change clutch.
did you resurface it when you put the new clutch in?
Narcissistic fade away
yeah.. it is a waste of time and money to surface a flywheel and NOT install a disc.. just change the seal..
