1 - 3 of 3 Posts
MY DOOR LEAKS WATER SOOO BAD AND ITS RATTLING LIKE WHEN I HIT A BUMP, IT MOVES UP AND DOWN, HAS ANYONE HAD THIS PROBLEM? IM SURE THE WATER LEAK IS FROM THE DOOR LOOSE AND I PROBABLY NEED NEW WEATHERSTRIPING BUT HOW DO I TIGHTEN THE DOOR TO WHERE IT DOESNT RATTLE?
Foxaholic
Check the door striker and the hinge pin bushings as well. The hinge pin bushings can be checked by pulling up and down on the door while it is open. If there is any play then they need to be replaced. The striker has a plastic covering that goes around the striker that gets worn out. You can get a new one at any Autozone. The striker is also adjustable up/down/left/right to adjust the position and tightness of the door while it is shut.
you should check how worn your weatherstrip is also
1 - 3 of 3 Posts
