Open or close under vaccuum? I've been dealing with gas fumes in the car while stopped due to having breathers in my valve covers and I am wondering if running a couple of PCV valves would help the situation.
Discussion Starter · #4 ·
DarkPony said:
I would go ahead and put a pcv back in, I ran them on my black car with no problem, I would run the pcv hose to the inlet pipe, that is where mine was.
I put the breathers on because the crank case is slightly presurized at idle and was putting fumes into the intake, causing the car not to idle.
