http://www.competitionplus.com/11_13_2002/diesel_doug.html
"...What you see before you is the world's quickest diesel truck. This beastie is good for 9.27 @142 mph down the 1320...
...The drive train of this vehicle is obviously the biggest conversation piece. It's powered by a 318 cubic-inch, 21.1 compression, twin-turbo, nitrous injected, fully aluminum Detroit Diesel. Doug claims 850 horsepower and a mind numbing 1600 ft/lbs of torque @ 68 pounds of boost!
...The rest of the drive train is built around the 1,050lb all-aluminum motor, "I use a Crower 4-disc clutch, a 4 speed Lenco and a Mark Williams 9-inch rear-end with 2.75 gears." As far as maintenance goes, Doug said, "If I de-tuned 50 horsepower out of it and didn't fiddle with it, I could go a whole season without lifting a valve cover."
