Dart Heads
348 Views 8 Replies 6 Participants Last post by  5.0thunder
Anyone have any Dart heads on their 5.0? Since starting Auto Tech 2, i wanted to install a cam but not to big of one that i would have to replace my heads, but my teacher is a distributor of Dart everything and said he can get good prices on heads for me if i wanted to get a better cam. What is everyones opinion about the Dart heads?
i put them on a friends car, and it ran pretty good.
the set up was
302
dart 195's
xe282hr
lt's
the car ran very hard up top
I'm a big fan of them
302
Trickflow intake
e-cam
Dart sr heads
300rwhp
302
Trickflow intake
e-cam
Dart sr heads
300rwhp
ok let me ask you this, cause that is almost the set up i was thinking, would you have switched to a different cam if you could? I was thinking about getting a FRPP B303 or a tfs1
302
Trickflow intake
e-cam
Dart sr heads
300rwhp
and what Tb/MAS and injectors did you use? I was thinking 24lb injectors with a 75mm Tb and 70mm MAS
B cam is ok Id get a TF cam or a comp cam if it was me, 70 mm tb 76 mm mass and 24 lb injectors
I'll make you a cam with a 100% refund if you are not totally happy with it. I doubt you will find that anywhere else.
Keep the heads on the smaller side of runner volume. Worst case scenario there is you might give up a touch of power at the top of the stairs, but up to that point, you'll be ahead of the game. The track will prove it and so will the fuel bill.
hahaha i was just about to tell you to ask shaunT about it. hes the man to go to.
