I am wondering if the factory spider gears are a harder and stronger metal, than the normal 28 spline surface on the axles?
Because I'am thinking my axle splines are wore and making a clunking noise in my rear end. Ive had new shims and all new berrings replaced in the rear end. So this is the last thing that would be loose. I should have looked harder when the shop had it out.
Just seeing if the gears would be wore as bad as the axle splines... any know?
