also, is there a particular year housing that is 3" OD inlet and outlet?
Thanks
Thanks
Awesome, thanks for the information. There is a "known" vq map for my computer to use a maf calibrated for a 24lb mustang combo, if i were to go with a 19lb or 42lb ford maf I would likely have to re scale my maps. So if both maf's can accurately meter air (albeit at a different voltage from each other) then I think I will try to use a 24lb.Oh, and if you multiply your MAF size by .039375 you will get the english sizes..
I.e. 77MM X .039375 = 3.031".
Rescaling is a gauranteed thing, I am sure of that. I'd just be worried about maxing the voltage / Kg/hr the meter is calibrated for. If it goes static, like you mention, that is not good. On a ford, using whatever binary you want - the 24# meter will simply not flow enough to support 500HP on a forced induction car.Awesome, thanks for the information. There is a "known" vq map for my computer to use a maf calibrated for a 24lb mustang combo, if i were to go with a 19lb or 42lb ford maf I would likely have to re scale my maps. So if both maf's can accurately meter air (albeit at a different voltage from each other) then I think I will try to use a 24lb.
I am not familiar with how tweecer and diable maps look, but on my computer, if the air flow goes past the end of the scale (whatever voltage is in my last load cell) the computer will just use the last load cell.
