In your truck?
Does the unit come on? And have you change out your filter? When I use to live in Carrollton I had fire ants build a mound inside my unit and it didn't blow cold air. You might want to check for that.Nah in the house.
God bless
sorry man i was on the other line with milk's homey. hes gonna get me fixed up. thank you.tried to call, u didnt answer!
please explain how not changing your filter would cause the a/c to blow warmer air?Does the unit come on? And have you change out your filter? When I use to live in Carrollton I had fire ants build a mound inside my unit and it didn't blow cold air. You might want to check for that.
I can fix it call me at 817-4689922 I charge $69. to Diagnose and then give you a Bid Thanks John Sheffieldcan anyone get this solved yesterday for me?? 817-946-1352
i35 and 121
god bless.
Airflow across the evap maybe, lines freeze, then someone gets pissed and hot.please explain how not changing your filter would cause the a/c to blow warmer air?
Don't ask me. When the AC guy came out to my house and found out about the fire ants he ask me if I changed out the filter before he checked everything. So that is why I ask elvis that. But hey you know everything so fix his problem douche.please explain how not changing your filter would cause the a/c to blow warmer air?
no airflow across your evap. coil which causes the coil to freeze up into a big ass block of ice...thus no cold air out of vents....please explain how not changing your filter would cause the a/c to blow warmer air?
LOL, happy birthday!milks homey ulises showed up early and found the problem in about 2 minutes. a capacitor has shit out. he didnt have the exact one with him so he will be stopping by this morning to get me fixed up. Thanks Milk!!!!!!!!!!
god bless.
