I have a 99 durango that just started to act up this morning, it idels ruff and runs ruff, the engine lights comes on, and flashes when you acclerate any suggestions, and is there a code scanner that i could buy that i could hook up to the car to see what codes are popping up .
· R.E.N.G.
i would bet plugs or something is loose related to plugs, had a similar problem in my car.
Sucking in unmetered air could do that. Check for vacuum leaks and MAF connections. Did you do anything recently under the hood? You could buy a scanner, but the OBDII scanners aren't cheap. See if Autozone will do it like the previous poster said.
Discussion Starter · #5 ·
i check the plugs found one cylnder missing , we change spark plugs and check wires still did not fix the problem going to have a repair shop hool up a computer to it and see what it finds
