Maybe we can start a V6 section on this forum like the corral??
Anyways, I have a 98 V6, and I heard about swapping for the 99+ split port intake,
1. Would you have to switch computers?
2. Would you have to switch the fuel system (returnless?)?
3. Other changes required.
Has anybody tried this?
Thanks,
Mike
· Im Not Fat Im Big Boned !
I had a 98 V6 and I thought it was just the intake that was different but when I was going to attempt that swap I was told that I needed diff. heads as well ?? I have seen another person do it without swapping heads but I dont remember how or what mods it took to do it ! ROB
the comp will need to be retunned-you wolnt need a new one, however you may look into buying a new chip-just depends on what you are wanting to do later or what you want it to do now. New heads are not required, but you will see more of a power increase with the new heads and the new intake, also the costs of haveing both done at the same time will save you in the long run. A larger MAF sensor will work best with the application you are choseing too. How long have you had the car and where did you get it??
