75mm S400 and Wastegate BOV Combo. $1299.00
280 Views 0 Replies 1 Participant Last post by  turbodave
Borg Warner S400/75mm wheel With Extended Tip Technology.
1050HP capable turbo,
1 year warranty. High Flow Race cover option available. Upgradeable for future power increases
Compressor Wheel Inducer - 75mm
Turbine Wheel Inducer/Exducer- 87/96
Turbine Wheel Trim - 96
Turbine Outlet - 5 InchV-Band
Turbine Inlet - T6
Turbine A/R - 1.32
Horsepower Rating - 500-1050
JGS500 50mm Wastegate
-Compact for complex installs
-All 300 series SS/
T6 Aluminum construction
-Anti creep geometry
-Silicone O-ring Piston Actuator,
for long life and easy service
-Nickel Aluminum Bronze Valve Guide
-Floating valve seat
-Externally clock-able
1/8” NPT side pressure ports
-2” V-band Connections,
Inlet compatible
with many other
V-band wastegates
-SS flanges, clamps, and
hose connections included
JGS 60mm Blow Off Valve
-60mm Valve
-All CNC T6 Aluminum construction
-Ground SS valve stem
-1/8” NPT pressure ports
-2.5” V-band Connection
-Aluminum flange (notched f/ 3” tube),
clamp, 3 springs
(4 possible combinations to tune for
vacuum/boost range),
and hose connection included
1 - 1 of 1 Posts
1 - 1 of 1 Posts
