1 - 20 of 33 Posts
Married Man on 14Feb2010
Crash Test Dummy
Discussion Starter #6
TexasDevilDog said:
Why is it that this guy can make over 501 and some guys can get their car started?
I don't see how anyone can spin a bearing in a 13sec car? :D
OLD SCHOOL crew
302_plus_a_few said:
I bet that thing doesn't last a season.
even you should be impressed with those numbers from a na motor ;)
Is it cold in here?
I made more than that with a wimpy stock 5.0 shortblock at the old Fastech. Sean Freese did the dyno!! I never even had the pan off of that motor:D :D
Crash Test Dummy
Discussion Starter #14
spankustang said:
Stock shortblock, crane 2031, canfield heads, holley intake, s-trim, and c-4:D :D
I've seen civics make 500fwhp with boost. The Ls1 in question did it N/A stock bottom end.
You just need a huge cam and good set of heads and the rest of the supporting bolt-on cast. :)
hmmm good heads, and a huge cam. Who else has those?
spankustang said:
obviously with wimpy trq # it's a 6sp car, so that means it'll run some 11.50's and then it'll come apart!!!
I guess you over looked this part.
"last time i went to the track i ran 10.58 @ 130 mph!! at that time we had
480 rwhp and 415-420 rwtq"
Keep your unicorns
Too bad Cartek isn't local or the LS1.com guys would have another tuner to worship. They even work on Pat Musi's car!
Is it cold in here?
The only LS1 that i've seen in the 10's is Sean's. I know there are a few more, but i also know that after about the 3 or 4th pass it'll break!!!!
1 - 20 of 33 Posts
