I am wanting to know which spindles are direct replacement when doing a 5 lug conversion on a 93 Mustang. The guy doing the rear end on my car screwed up and got a 5 lug rear end instead of 4. And since I already spent over a grand at the shop he is throughing in the conversion for free.
Still got Nothing
94 & up will bolt up. You will need to use a spacer on the fox ball joints or use SN ball joints. If you use 94/95, you will retain the fox track width, if you use 96 & up, it will about 3/4" wider on each side. In addition to that, if you use 99 & up, you will get dual piston calipers.
Is a drum or disc brake rearend? If it is drum, I will trade you 4 lug axels and drums for your 5 lug stuff. Let me know.
it is a disk brake set up. Since the shop screwed up on the rear end by getting the wrong year I am getting the full 5 lug conversion parts and installed for 325 bucks. It is being finished tommorow sorry.
