351w specs ?
388 Views 10 Replies 8 Participants Last post by  jyro
Im loking to build a 351w looking to see if year of the block has different specs and what years to look for then?
1 - 11 of 11 Posts
69 block in 351w has more nickle content.
That makes it stronger
'69-'74 model blocks are the strongest factory blocks. They have higher nickel content, and I believe the main webbing is thicker in general.
I think the '69 era 351W blocks had a 9.2" deck height instead of 9.5"
I've been messing around with the '95 era 351's with the roller lifter bores.
Close, you are thinking of 69 and 70 blocks which had a 9.480" deck height while later blocks had a 9.500" deck height.
They do make a 9.2" deck FMS block.
Oh yeah, that's right! I knew they were a little off...Thanks! :cool:
Short deck thru 70 , high nickel thru 74 . The only down side is the 2 pc rear main . When you get your kit make sure the crank will work in your block . Some stroker cranks are set up for 2 pc rear main and have a ridge that will need to be machined off if used in a later (79 up) 1 pc rear main block . Its nice to have an early strong block but with the power any 351 block can handle you will be fine . If you are going that crazy just get one of the new Ford Boss 351 blocks they just reliesed .
Excellent point about the rear main.
I have a 69 block for sale pm me.
Always fun when you find out after the fact . Been there , done that .
depends on what your plans are for it
Their all stronger than a 302 production block, most 351w's never have block problems no matter what year. Brooks bent 8 rods in his roller block, I bought it and am using it on a blown alcohol motor for the last 3 years.
1 - 11 of 11 Posts
