1 - 18 of 18 Posts
Well long story short, I've done the swap and trying to hook up my H-pipe ( have vert motor mounts). The clearance is good but the H-pipe bolted up and the driver side header sealed but the passenger side did not... it only sealed about halfway like the angle of the pipe was off.. I think I may have gotten screwed on my swap headers theirs no brand stamped. Just curious if anyone has run into this problem as well. I'm thinking I might be able to cut the H section and bolt the tubes up by them selfs and then maybe all I would have to do is a small bit of fab work. to the H section to get everything to fit right. Anyone else have to do this? (Mine is an 85gt that I'm doing mine in with a T-5)
Thanks
Thanks
the 351w is a little wider i think than a 5.0. i ran into this same problem when i put a 393w in my a 95. i just took it to an exhaust shop and had them bend the pipe on the side that wasnt sealing over a little.
Full tilt boogie !!
I'm sure any muffler shop can make the hpipe fit. If you werent in saginaw i would say takeit to Muffler king in Dallas, i know he can fix it.
Discussion Starter · #4 ·
Nice, thanks that's all I could come up with man it was late and I was pissed just trying to get it to seal. But I think I egg shaped the bottom of my header a little so I hope I dont have to buy new headers. If so what headers did you use?
in my car i was running mac shorties for a 5.0 (not 351w swap) and normal energy poly motor mounts. i ran an ebay h-pipe that i had to take to the muffler shop and have them bend a little which is what i mentioned above.
Hmm thats good to know I was worried about clearance. I'm thinking if I did trash my header I'd order the BBK shortys. The price isn't too crazy and haven't heard anything bad about them. The longtubes look like a bitch!
they are. i had a buddy with a 351w in his 95' also and he said the longtubes weren't worth the trouble in his opinion. plus he said it's a pain to access the starter with them.
Brawlin Bird
I noticed the ball flange on my BBK 351 swap shorties was a little egg shaped right out of the box . Its always hard to get the passenger side to not leak .
Discussion Starter · #10 ·
Thanks for the responses, I got my h-pipe apart I'll see how it goes. I do have another question. I noticed my intake was leaking at the rear (Doh) so I'm gonna fix it. I currently have a b cam in it with some SVO 1.6s I don't believe I'll be very pleased with it. I'm thinking of swicthing to a TFS stage one or two cam. I have some Holley sys. max 2s that have been ported and I'm running a macthed Vic Jr. and some shortie headers. Any suggestions on either cam? (Car is a 5speed car)
Thank you.
Thank you.
you'll be much happier if you get a custom cam matched to your set up.
Semi-Banned
BBk long tube headers are the shit!
I've had some on a car in about 15 minutes because they fit so damn smooth.
Loosened the motor mounts one at a time and lifted the engine from the crank and they slid right in; and I had easy access from both above & below.
Narcissistic fade away
If you are in Saginaw, just take it to Phils muffler shop on Main street - he's done a LOT of work for me and several of the board members. Super cool guy and great work.
He's right on main street just before the long street intersection.
Sign I saw on the ground:
As the 351 is taller & wider, the 351 swap header is not designed so much to allow you to bolt up to your old exhaust as it is to give you shorties w/ workable clearances.
Discussion Starter · #15 ·
He is good I've used him for everything.
Brawlin Bird
Thank you.
I have a TFS 1 in my 351 and it is small for the combo but the torque and drivability is great for a heavy auto vert . I would suggest a larger cam for your combo .
Discussion Starter · #17 ·
Im thinking of going with a TFS stage 1 cam I've heard alot of good things...
Brawlin Bird
If you wanna see how it runs come on over and go for a ride with me . That may help you make up your mind . I am in North Richland Hills so it aint far .
1 - 18 of 18 Posts
